  1. Hi guys!
    Just a quickie on IFOEDIT and I hope some GURU out there can help!
    When I split a DVD9 to 2 x DVD5, i use IFOEDIT to split to two DVDR, copy across the remaining files and use IFOEDIT to change the second disk to start straight into the movie.
    Now problem is on some disks after the first half of the file ends, the DVD thinks the entire end of the film has been reached and starts playing some harsh copyright WARNING messages, that you would never normally read as you would have switche off the dvd by this point. What I want to know is how do I tell the dvd to return to the main menu screen after playing the first half of the movie instead of going onto the warning screens? I've done a search, but to no avail can anyone help?
    Mar 2003
    Uranus
    If you can identify the warnings section in Ifoedit ,
    you can hit DELETE Playback. That doesn't delete it,
    it just makes the PGC jump around it.
  3. Thanks for the help again FOO, that's the second time today you've come to my rescue! Geez, what would I do without you. I'll give this a try and then get some sleep so you can go take a rest brother! :P
    Have a good one and thanks again
