I encoded an avi file with tmpgenc using the dvd pal option. The output file is an mpg file. My dvd software is looking for .ifo files so i cannot reproduce the output file to my pc. How can one create the hole dvd file structure with tmpgenc?
You have to author the DVD with authoring software. Just converting a file into mpg is not enough. Check out tools on the right for one that suits your needs. Also, look at the DVD authoring guides.
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52 -
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 19:20 -
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 07:09 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 12:50 -
Help with output after editing with tmpgenc 4.0 xpress
By uka100 in forum EditingReplies: 2Last Post: 14th May 2008, 20:30
