Is there any diference in how Divx movies are looked like on 42" Plasma vs. regular (rear-projection?) 42" TV? I want to play it from Divx Player 2.5, fullscreen, TV-out from AIW9700.
Thanks for any comments, ideas, links.
older generation 1-2 or so blacks looked awefull on plasma ... but many today are much much better ... most rear screen tvs are crt based (but now many are lcd and even dlp now - but more expensive) ... it really all depends on the models compared as many have a big diff on how they look ...
you dont have to clamp your color levels though ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Don't most plasmas use a VGA connector too. It would look much better if you use the VGA. If you haven't bought a plasma yet, make sure to buy one with a VGA connection.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
many have DVI -- which looks better than VGA , since VGA is the same as rgb .... though both a step up from s-video ... all have component now though (i think) ..
I never see DLP at bestbuy, circuit city, or anywhere for that matter. Has anyone ever seen dlp projectors in a major retail store? (/link?)Originally Posted by BJ_M
Samsung DLP's at Fry's Electronics and Best Buy. Im getting the new LCD rear projection Sony.
Samsung DLP at Best Buy: http://www.bestbuy.com/site/olspage.jsp?id=1051806301003&skuId=5333472&type=product&pr...oryId=cat03006
Plasma or LCD
By hardy in forum Off topicReplies: 12Last Post: 1st Dec 2010, 18:12 -
New to Plasma/LCD/LED. Should I buy this plasma screen if I'm a gamer?
By Hank Kinsley in forum DVB / IPTVReplies: 4Last Post: 1st Nov 2010, 16:33 -
Using Plasma TV to monitor
By thadisrad in forum DVB / IPTVReplies: 35Last Post: 15th May 2009, 07:45 -
Tv To Plasma Using S Video
By krisyrfc in forum Newbie / General discussionsReplies: 34Last Post: 12th Feb 2008, 21:46 -
LCD or PLASMA.... WHich is best..and why..?
By snadge in forum DVB / IPTVReplies: 2Last Post: 1st Sep 2007, 17:49
