i have buy the new Plextor PX-708A and the Sony DVD+R (DPR120N2) but i have a problem with final burning, i use Nero 6 (6.0.0.15). what can i do?
here the Log report from Nero 6:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10.09.1999 13:06:00
ahead WinASPI: File 'C:\Programme\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17.06.2003 15:25:04
Nero Version: 6.0.0.15
Recorder: <PLEXTOR DVDR PX-708A> Version: 1.01 - HA 1 TA 1 - 6.0.0.15
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <TOSHIBA DVD-ROM SD-M1612>Version: 1004 - HA 1 TA 0 - 6.0.0.15
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1800JB-00DUA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1000BB-32CCB0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : TOSHIBA DVD-ROM SD-M1612 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PLEXTOR DVDR PX-708A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 2 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 3 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 4 DMA: Off
=== CDRom-Device-Map ===
TOSHIBA DVD-ROM SD-M1612 L: CDRom0
PLEXTOR DVDR PX-708A M: CDRom1
AXV CD/DVD-ROM N: CDRom2
AXV CD/DVD-ROM O: CDRom3
AXV CD/DVD-ROM P: CDRom4
AXV CD/DVD-ROM Q: CDRom5
AXV CD/DVD-ROM R: CDRom6
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523800kB)
Free physical memory: 249MB (255084kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.10.2003
UDF/ISO Zusammenstellung
19:39:00 #1 Phase 112 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation started
19:39:00 #2 Phase 114 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation completed (no file modified)
19:39:00 #3 Text 0 File Isodoc.cpp, Line 5878
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
19:39:00 #4 Phase 111 File dlgbrnst.cpp, Line 1843
DVD-Video files sorted
19:39:00 #5 Text 0 File Reader.cpp, Line 118
Reader running
19:39:00 #6 Text 0 File Writer.cpp, Line 127
Writer PLEXTOR DVDR PX-708A running
19:39:00 #7 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
19:39:00 #8 ISO9660GEN -11 File geniso.cpp, Line 3861
19:39:00 #9 Text 0 File Burncd.cpp, Line 3168
Turn on Disc-at-Once, using DVD media
19:39:01 #10 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 1228063 (272:54.13)
19:39:01 #11 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
19:39:01 #12 Text 0 File DlgWaitCD.cpp, Line 1885
Recorder: PLEXTOR DVDR PX-708A, Media type: DVD+R
19:39:01 #13 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
19:39:01 #14 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1228064 (1228064) = #1228064/272:54.14
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1228064 blocks [PLEXTOR DVDR PX-708A ]
19:39:01 #15 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [PLEXTOR DVDR PX-708A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 2515382272, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1228064 | lead-out | 1 | 0x00 | 0x41
19:39:01 #16 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
19:39:01 #17 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
19:39:01 #18 Phase 28 File dlgbrnst.cpp, Line 1843
Speed measurement started
19:39:01 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:49:01 #20 Text 0 File WriterStatus.cpp, Line 113
<PLEXTOR DVDR PX-708A > start writing Lead-Out at LBA 1228064 (12BD20h), lenght 0 blocks
19:49:01 #21 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:49:01 #22 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
19:49:01 #23 Phase 29 File dlgbrnst.cpp, Line 1793
Speed measurement completed: 51,7x (71.346 KB/s)
19:49:01 #24 Text 0 File Burncd.cpp, Line 4131
Es kann nur mit 2x anstatt 4x geschrieben werden,
da die Geschwindigkeit der Datenquelle zu gering ist.
19:49:01 #25 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 2,4x (3.312 KB/s)
19:49:01 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2136
19:49:01 #27 SCSI -1066 File Cdrdrv.cpp, Line 1203
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02E95000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
19:49:01 #28 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 13:12,342 (792342ms) -> OK
19:49:01 #29 Text 0 File DVDPlusRW.cpp, Line 555
Start write address at LBA 0
DVD high compatibility mode: Yes
20:01:49 #30 Text 0 File WriterStatus.cpp, Line 113
20:01:49 #31 Text 0 File ThreadedTransfer.cpp, Line 228
20:01:49 #32 SCSI -1067 File Cdrdrv.cpp, Line 1203
Sense Code: 0x26
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x00
20:01:49 #33 SCSI -1176 File Cdrdrv.cpp, Line 1203
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x04
20:01:49 #34 Text 0 File dlgbrnst.cpp, Line 1703
20:01:49 #35 CDR -1067 File ThreadedTransferInterface.cpp, Line 1626
Invalid field in parameter
PLEXTOR DVDR PX-708A\H1 T1
20:01:49 #36 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1626
Could not perform end of Disc-at-once
20:01:49 #37 Text 0 File dlgbrnst.cpp, Line 1703
20:01:49 #38 Text 0 File dlgbrnst.cpp, Line 1703
20:01:49 #39 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 2,4x (3.312 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10.09.1999 13:06:00
File 'Drivers\PXHELP20.SYS': Ver=2.02.53a, size=17136 bytes, created 04.10.2003 22:54:20 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29.08.2002 01:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Where is firmware 1.02? Newest I can find is 1.01.Originally Posted by Scoty
peace.
unloaded -
Firmware is here, changelog in japanize only
http://www.plextor.co.jp/support/firmware/PX708A_102.exe
http://www.plextor.co.jp/support/firmware/PX708A_102.txt
Jon
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 18:01 -
Question about Working with Audio Channels in Sony Vegas 11 (
By thirdmainroad in forum AudioReplies: 3Last Post: 5th Jan 2012, 11:49 -
Sony RDR-HX710: remote not working, how to access recordings?
By disconnekt in forum DVD & Blu-ray RecordersReplies: 10Last Post: 4th Feb 2011, 04:01 -
Sony Vegas 8 VOB not working
By Illusionist in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2009, 02:06 -
Sony file interface surrogate (not visible) has stopped working
By vicfurth in forum EditingReplies: 0Last Post: 27th Oct 2009, 15:47
