On several recent attempts to make a backup, DVD Backup works fine, but DTOX goes all the way to 99% and stays there hanging for about three hours?
Anyone else notice this?
It's when I'm doing full disc copy, with all languages, it doesn't seem to happen when I choose one language, but in this case, I really want the commentary.
ive had this on a few and found that the resulting dvd was not affected at all....
you could try another backup method other than dvdbackup say like OSeX and see if there isnt something that it missed when backing it up.
oh, make sure the dvd is clean and lint/dust/smudge free
other than that, id say just force quit it and see if anything was affected.. -
Are you using the latest version of DVD2OneX? The first couple versions had this problem, but it was corrected in version 1.1x. Make sure you're running the latest version.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Ah, so Wise Weasel....you have provided the solution, I didn't know they'd updated the software..of course, no sooner do I update and get one movie done, then they release a SECOND update!!!!
Truly, the ways of software makers are strange...but the prob's all fixed, so I be a happy burning fool!
Now when are they gonna release 1.3, with the join feature???? -
Originally Posted by Dunnyman
/Rob
[/b]
Weird DVD Burner issue
By Noahtuck in forum ComputerReplies: 1Last Post: 8th Nov 2011, 18:52 -
Weird issue with DVD to H.264
By reakt in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 18:15 -
Very weird hard drive issue
By alegator in forum ComputerReplies: 3Last Post: 12th Jun 2008, 12:03 -
weird TV as a second monitor issue
By pheldd in forum Software PlayingReplies: 14Last Post: 6th Nov 2007, 04:48 -
Really, really weird issue with NEC 3550A
By ioannisds in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st Jul 2007, 14:07
