    Aug 2002
    England
    Hi
    When converting a divx/xvid to DVD Pal 720 x 576 how do u guys work out the aspect ratio??
    e.g. 608 x 256 .... what would the new scale be?? 720 x ???
    I figured 720 divided by 608 multiplied by 256 which would be 720 x 303
    But this creates a video narrower than the original .. any ideas?
    Has anyone developed a formula for working this out so that they remain the correct aspect ratio??
    Please don't recommend using a script I want to do it from within the program.
    Cheers
    Fozzee
    Mar 2003
    Uranus
    The storage aspect ratio in a MPEG2 file has nothing to do with
    the DisplayAspectRatio. 720 x 576 could be 4:3 or 16:9
    You need to determine what the original is SUPPOSED to look
    like. It it really 2.375:1 ?
    Then you will have probably letterbox it and re-encode.
    Find DJRumpys' Guide. That explains lots.
    I add black bars and make it true 4:3 using 352x480. Yeah, I lower quality a little trimming down high-resolution source. But it was a download after all (normally movie trailers).
    I have MC 1.4 in demo mode right now for testing, but I'd just as quickly use TMPGEnc for this kind of conversion project.
    Aug 2002
    England
    I'm sorry I don't understand this post at all.
    What is a storage aspect ratio??
    DJ Rumpys guide to what?
    Fozzee
    Aug 2002
    Divx/Xvid is almost always made with square pixel format, so I suggest using FitCD and set source to 1:1 pixels and calculate a resizing to be used on DVD. Mainconcept 1.4 can open avisynth scripts without problems, just choose all file types when opening and select the avs.
    Ronny
