I have just used BeSweet to convert my mp2 from a TV Capture to AC3. The AC3 is quieter than the MP2. Is this normal?
I have noticed that other programs such as Soft Encode and Surcode have areas for all 6 channels. How would I even get DD 2.0 if I only have one source file?
And the same question goes for BeSweet, does it create a stereo DD 2.0 file or are both channels exactly the same which would mean it is mono?
FT Shark.
Easy ..In surcode..you just load open the file 3 times this then gives you 6 Channels (ie DD 5.1).
You can then change the encode settings, (i.e. Bitrate, pro-logic surround settings/volume, LFE settings) hit encode and eventually it will spit out an AC3 file.
Of course its not 'true' surround sound, as you only started off with stereo but I find it can certainly enhance a dull stereo track -
Ok A lot of people asked this question.!! You want 6 channel from 2 channel? It can be done It's the closest to true 6 channel You have to re-engineer the sound. This is what you need
A good pair of ear (I'm not kidding)
Alot of time (is it worth it?)
Goldwave
Soft encode or Surcode
First create 3 wav file from your source. I supposed you know how to create a wav file.
Next duplicate the wav to 2 extra sets(simple just copy and paste)
Load 1st set to goldwav (this would be your surround sound-back speakers) Here you adjust the bandwith to mid and low bass by using the filters and parametric EQ Cuts out all vocal option. You have to do trial and error method. Not really difficult. Bandwith not lower than 250Hz. A little leeway-played around with it. After adjusting all the bandwith, you have to increase the volume back in relation to your main sound from your front speakers. Again trial and error.Fortunately you can preview the sound .Didn't I tell you you need a good pair of ears!!
Next do likewise for the centre and subwoofer,adjusting the bandwith etc..
You end up with 6 tracks. Load into Softencode and mux into 6-tracks ac3
Steep learning curve!! Happy experimenting. Lets us know the outcome OK?
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
