I'm creating a 3-disc SVCD from DV AVIs. I used TMPGEnc to encode the video and audio separately. (video is VBR 1635kpbps).
I muxed the first disc with bbmpeg and it worked just fine. I tested entrypoints and it works fine on my dvd player.
I did the same with the second disc. Same average bitrate. With the SVCD mux settings from the how-to on this site, there's a warning about DTS/PTS underflow (I think those were the letters).
The file I get isn't seekable in windows media player, and I can't seek to a time when playing on my standalone (Apex AD-600A). FF and Rew work, but it won't seek like the first one did.
I tried to set the mux rate higher (I think). The default is 6972. I set it as 0, and i think it did 7000. I also tried it at 7020. I don't know if ths helped. I don't think so, since this is 6972 even before you load any file. I guess it's part of the SVCD spec. None of those settings resulted in a file that i could seek.
I tried to mux it with TMPGEnc and that didn't help either.
Edited to say: The m2v file plays fine with media player, and seeks just fine too.
Any suggestions?
Dan
<font size=-1>[ This Message was edited by: Leehro on 2001-10-06 21:49:37 ]</font>
May I suggest DVD2SVCD?
I friggin LOVE this program - it's so EAAAASY 2 use.
And mucho flexible.
you want it on 2 discs? BAM
there you go
3? viola!
If a movie is around 95 mins, i've even squeezed it onto 1 80 min CD! The Cell looked awesome as a 1 CD SVCD.
http://212.88.77.140/
go 4 it!
Oh dear. This calls for a very special blend of psychology ... and EXTREME VIOLENCE.
Oh, and I muxed it with VBR OFF, and set the mux rate to 10000. The file i got was 1.5GB and I could seek just fine. Any way to get bbmpeg to pad or something? Whenever I had vbr on, it didn't matter what i set the mux rate too, i always got the same size file.
Dan -
Try setting the Mux Rate at 0. It will then automatically choose a mux rate for you.
Yep i tried setting it to 0. Put that in my original post. No matter what I had the mux rate set to, if VBR was checked, I got the same size file every time. I don't mind some extra space but I do need it to fit on an 80 minute disc...
I'll try muxing at just above the average bitrate, with VBR muxing off. don't think it will work though.
Dan
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 19:27 -
problems with favc and the muxing of the dvd
By kronick in forum Authoring (DVD)Replies: 10Last Post: 7th Sep 2009, 17:05 -
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 19:49 -
Problems muxing MPEG2 with layerII Ac.3
By Bonzo2002 in forum ffmpegX general discussionReplies: 0Last Post: 23rd Jun 2007, 11:04 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 15:14
