I was able to capture with virtualdub before but now I get an audio error message. It says soemthing like audio error: check your frequency, channels, or bit rate? I have the wrapper installed and I use the latest drivers from ati. Could the new ati wdm drivers have something to do with this? Does anyone else have a problem with capping in Vdub?
Here is the exact text of the error message.
error 419: Cannot open the wave input device. Check sample size, frequency, and channels. -
I have tried everything and I can't get Virtual Dub to capture anymore. The video portion works just fine. It is the audio portion. Does anyone know how to fix this Error code 419? Please help! I have seen that other people have had this problem but I have never seen a solution. Remember it worked before so there must be a way to get it back.
Thanks. -
Never met a problem like this. Can you hear audio at all? Maybe you should check all the audio connection cables and make sure they are firmly connected. Just several days ago, VirtuaDub suddenly couldn't find cap driver on my computer anymore. I tried to reinstall the drivers, then my computer can't find the card. I had to open the case and make sure the card is firmly plugged in the PCI slot. It turned out to be the problem. Basically a reinstall.....
I really don't know what it is. I hear the audio before I hit capture and my video capture card still works with every other program. It seems like there is a problem with the sound card configuration. Apparently it can not find the sound card input. Maybe my mixer settings are wrong? Oh well I will just keep messing with it. I have installed DX9b, Visual Studio 2003, and the latest ATI software and drivers. Maybe one of those messed up my sound card config? If anyone sees this error message plaes let me know.
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 12:07
