  1. i dont no if its my burner.i have burned alOT of vcd svcd and i have never had this problem befor.all my burning programs dont work.have anyone had this problem.it willnt get by the buffer level.i saved the log from nero.this is what the log said.
    andy
    marsh family
    1A23-0006-7130-1204-8976-4901
    Windows 98 4.90 (ME)
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 6/8/2000 5:00:00 PM
    ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 3:25:04 PM
    Nero version: 6.0.0.15 (Nero Express)
    Recorder: <LG CD-RW CED-8080B> Version: 1.04 - HA 0 TA 1 - 6.0.0.15
    Adapter driver: <ESDI_506> HA 0
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <SAMSUNG DVD-ROM SD-616 >Version: F000 - HA 0 TA 0 - 6.0.0.15
    SAMSUNG DVD-ROM SD-616 (Target 0, D: Autoinsert Off, DMA Off, Disconnect ?, SyncDataXfer ?
    LG CD-RW CED-8080B (Target 1, E: Autoinsert Off, DMA Off, Disconnect ?, SyncDataXfer ?
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 24117248 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 126MB (130024kB)
    Free physical memory: 21MB (21760kB)
    Memory in use : 100 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    6.10.2003
    Video CD
    11:12:55 AM #1 Text 0 File Isodoc.cpp, Line 5878
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 2 / XA
    ISO Level : 2 (Max. of 31 chars)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    11:12:55 AM #2 Text 0 File VCDDoc.cpp, Line 2577
    VCD options:
    Create standard compliant CD: YES
    Encoding resolution: NTSC
    11:12:55 AM #3 Text 0 File Reader.cpp, Line 118
    Reader running
    11:12:55 AM #4 Text 0 File Writer.cpp, Line 127
    Writer LG CD-RW CED-8080B running
    11:12:55 AM #5 ISO9660GEN -11 File geniso.cpp, Line 3861
    First writeable address = 0 (0x00000000)
    11:12:55 AM #6 ISO9660GEN -11 File geniso.cpp, Line 3861
    11:12:55 AM #7 Text 0 File Burncd.cpp, Line 3169
    Turn on Disc-at-once, using CD-R/RW media
    11:12:56 AM #8 Text 0 File DlgWaitCD.cpp, Line 230
    Last possible write address on media: 359847 (79:59.72)
    Last address to be written: 15404 ( 3:27.29)
    11:12:56 AM #9 Text 0 File DlgWaitCD.cpp, Line 235
    Write in overburning mode: FALSE
    11:12:56 AM #10 Text 0 File DlgWaitCD.cpp, Line 1878
    Recorder: LG CD-RW CED-8080B;
    CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
    ATIP Data:
    Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
    Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    11:12:56 AM #11 Text 0 File DlgWaitCD.cpp, Line 393
    >>> Protocol of DlgWaitCD activities: <<<
    11:12:56 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 769
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE2_2336 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 1292 (1292) = #1292/0:17.17
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 1292 blocks [LG CD-RW CED-8080B ]
    1: TRM_DATA_MODE2_2336 (Dawn Of The Dead (dvd-rip)(Eng))
    original disc pos #0 + 13963 (13963) = #13963/3:6.13
    relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 13963 blocks [LG CD-RW CED-8080B ]
    11:12:56 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 938
    Prepare recorder [LG CD-RW CED-8080B ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x20; Session Closed, disc fixated
    Tracks 1 to 2:
    1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 3391584, ISRC ""
    2: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 3391584 3744384 36585360, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    -150 | lead-in | 0 | 0x00 | 0x41
    -150 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    1292 | 2 | 0 | 0x00 | 0x41
    1442 | 2 | 1 | 0x00 | 0x41
    15405 | lead-out | 1 | 0x00 | 0x41
    11:12:56 AM #14 Phase 73 File dlgbrnst.cpp, Line 1843
    Preparing items
    11:12:56 AM #15 Phase 24 File dlgbrnst.cpp, Line 1843
    Caching of files started
    11:12:56 AM #16 Phase 25 File dlgbrnst.cpp, Line 1843
    Caching of files completed
    11:12:56 AM #17 Phase 36 File dlgbrnst.cpp, Line 1843
    Burn process started at 8x (1,200 KB/s)
    11:12:56 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2136
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    11:12:56 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
    Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #1442
    11:12:56 AM #20 Text 0 File Mmc.cpp, Line 14512
    StartDAO : CD-Text - Off
    11:12:56 AM #21 Text 0 File Mmc.cpp, Line 14832
    CueData, Len=48
    41 00 00 34 00 00 00 00
    41 01 00 21 00 00 00 00
    41 01 01 21 00 00 02 00
    41 02 00 21 00 00 13 11
    41 02 01 21 00 00 15 11
    41 aa 01 34 00 03 1b 1e
    11:13:47 AM #22 SCSI -1119 File Cdrdrv.cpp, Line 1411
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02040000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x09
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x1B 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x09 0x00
    11:13:47 AM #23 CDR -1119 File Writer.cpp, Line 335
    Track following error
    11:13:47 AM #24 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    11:13:48 AM #25 Text 0 File ThreadedTransfer.cpp, Line 222
    conversion idle, stopping reader
    11:13:48 AM #26 Text 0 File dlgbrnst.cpp, Line 1703
    Set remaining time: 0:00,000 (0ms) -> OK
    11:13:48 AM #27 Phase 38 File dlgbrnst.cpp, Line 1843
    Burn process failed at 8x (1,200 KB/s)
    Existing drivers:
    File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/2002 11:55:38 AM
    File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (094), size=197984 bytes, created 8/5/2003 9:13:12 PM
    File 'IoSubsys\CDRALVSD.VXD': Ver=1.00 (1037), size=20043 bytes, created 8/5/2003 9:13:12 PM
    File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 8/5/2003 9:13:12 PM
    File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 6/8/2000 5:00:00 PM
    Registry Keys:
    dose anyone no what this means PLEASE HELP I CANT BURN ANYTHING
  2. re-install writer and nero.
    get some more memory 128mb is no good in todays modern multimedia world. To enjoy video data to its fullest install 256mb or better 512mb.
    Burn with ALL other programs closed down.
    defragment your hard disk.
    Get a lens cleaner disk.
    The electronic components of the power part adopted a lot of Rubycons.
  3. re-install writer and nero.
    re-install writer?is writer a program on my PC?how do i install 256mb 512mb?em i installing my burning programs wong?i deleted my PC and started over and im still have burning problems with nero and Alcohol 120%.i have defragment my pc and scaned my pc for errors no error.IM ABOUT TO SHOT MY SELF PLEASE HELP SOMEBODY WITH MY BURNING PROBLEMS
    THE LOG FROM NERO
    HERE ARE THE ERRORS WITH NERO
    SH#T BOX IS THE NAME OF MY PC
    sh#t box
    1502-0001-0008-0488-4424-9831
    Nero Version: 5.5.9.14
    Recorder: <LG CD-RW CED-8080B> Version: 1.04 - HA 0 TA 1 - 5.5.9.14
    CD-ROM: <SAMSUNG DVD-ROM SD-616> Version: F000 - HA 0 TA 0 - 5.5.9.14
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 20971520 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Free physical memory: 0MB (140kB)
    Use Inquiry : 1
    Check supported media : Enabled (1)
    Wizard: On
    15.10.2003
    Video CD
    6:26:31 PM #1 Text 0 File Isodoc.cpp, Line 6887
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Burning mode : DAO
    Mode : 2 / XA
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Joliet : TRUE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    6:26:31 PM #2 Text 0 File Reader.cpp, Line 118
    Reader running
    6:26:31 PM #3 Text 0 File Writer.cpp, Line 127
    6:26:31 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4484
    6:26:31 PM #5 ISO9660GEN -11 File geniso.cpp, Line 4484
    6:26:31 PM #6 Text 0 File Burncd.cpp, Line 3588
    Turn on Disc-At-Once, using CD-R/RW media
    6:26:31 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 660
    Setup items (original item values)
    original CD pos #0 + 1112 (1112) = #1112/0:14.62
    relocatable, CD pos for caching/writing not required/required, no patch infos
    1: TRM_DATA_MODE2_2336 (the_simpsons-0201-_treehouse_of_horror_i)
    original CD pos #0 + 91800 (91800) = #91800/20:24.0
    relocatable, CD pos for caching/writing not required/not required, no patch infos
    6:26:43 PM #8 Text 0 File DlgWaitCD.cpp, Line 203
    Last address to be written: 93061 (20:42.61)
    6:26:43 PM #9 Text 0 File DlgWaitCD.cpp, Line 208
    6:26:43 PM #10 Text 0 File DlgWaitCD.cpp, Line 1420
    CDRW code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
    ATIP Data:
    Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 49 (LO 79:59.73)
    Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    6:26:43 PM #11 Text 0 File BurnCDUtil.h, Line 129
    Enable auto-insert wasn't successfull for all drives.
    6:26:43 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 812
    Prepare recorder LG CD-RW CED-8080B for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x20 Close CD
    Tracks 1 to 2:
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 2968224
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 2968224 3321024 219234624
    6:26:43 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 660
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 1112 blocks [LG CD-RW CED-8080B ]
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 91800 blocks [LG CD-RW CED-8080B ]
    6:26:43 PM #14 Phase 24 File dlgbrnst.cpp, Line 1571
    6:26:43 PM #15 Phase 25 File dlgbrnst.cpp, Line 1571
    6:26:43 PM #16 Phase 36 File dlgbrnst.cpp, Line 1571
    6:26:43 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1948
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    6:26:43 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 1948
    Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #1262
    6:26:43 PM #19 Text 0 File Mmc.cpp, Line 12622
    6:26:43 PM #20 Text 0 File Mmc.cpp, Line 12880
    CueData, Len=48
    41 02 00 21 00 00 10 3e
    41 02 01 21 00 00 12 3e
    41 aa 01 34 00 14 2a 3e
    6:27:33 PM #21 SCSI -1119 File Cdrdrv.cpp, Line 1381
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02160000
    Sense Code: 0x09
    Sense Qual: 0x00
    6:27:33 PM #22 MMC -1119 File Writer.cpp, Line 335
    6:27:33 PM #23 Text 0 File ThreadedTransfer.cpp, Line 222
    6:27:34 PM #24 Text 0 File ThreadedTransfer.cpp, Line 216
    6:27:34 PM #25 Phase 38 File dlgbrnst.cpp, Line 1571
    6:27:34 PM #26 Text 0 File Scsicmd.cpp, Line 402
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 9/11/2002 6:01:04 PM
    Registry Keys:
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Writer is the best DVD all-in-one software tool?
    Isn't that what you are using?
    It can slice dice and mutilate just about anything!
    You should install it. Reboot the computer. Then Uinstall it. Reboot the computer again then finally install it again.
    The program works great but there is a bug that makes you install it twice on some systems before it works.
    Go figure.
    Hope this helps!
    - John "FulciLives" Coleman
  5. You can never have too much ram. The more the better... The only real problem I see you have is Windows ME, I had that program and it's horrible with Burning. I had a Pentium III 900Mhz 512M PC133 SDRAM and it took 14 hours to convert DVD to VCD(MPEG) with TMPGEnc. It usually locked up half way through. Get Win98se or Xp and it'll solve a lot of your problems.
    Just my .02¢
