Hi Freinds,
The problem I faced after downloading *.avi files from P2P networks are too big to fit in a 80 or 90 min CD.
So can anyone can suggest me about how can I fit a big avi or mpg file to my 80/90 mins or even 99 mins CDs.
Note: big avi files mean like - a movie which shows 635Mb but when tried for VCD it is showing 131.33 min which can't fit to a CD!
MadKazaaUser![]()
An avi file is NOT a VCD format. You need to split the movie into two halves and ues each half to make a VCD.
I see, said the blind man to the deaf woman.
Don't confuse AVI file size with VCD/SVCD file size, they aren't related. A 700 MB AVi can be 30 minutes or 3 hours, 160x120 or 1024x768 in resolution.
VCD is 80 minutes per disk, fixed in bitrate, codec, and resolution.
SVCD is more variable, but the resolution is fixed. The Video and Audio bitrate have a maximum sum of 2550 kbps. This translates to roughly 40-60 minutes per disk.
Can't be true. Either you have an AVI or an MPG. 98% of P2P files will fit on a disk. 700 MB for an AVI, and 800 MB for VCD/SVCD.So can anyone can suggest me about how can I fit a big avi or mpg file to my 80/90 mins or even 99 mins CDs.
If you avi is 1300-1400 MB, then cut it in 2 with VDUB, 1950-2100 MB then cut it into 3 parts.
If you want to watch them in a standalone player, then convert them to VCD or SVCD or KVCD using the guides.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
To view the file, you have to convert avi to mpg. I recommend using TMPGEnc to convert. If they wont fit on the cd, then lower the bitrate and you should be able to burn. Good luck.
How to make these Avi files fit to Burn
By jkraze in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 21:24 -
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 13:35 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05 -
What authoring programs offer fit to disk using .avi files?
By dang in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 22:05
