Everytime i try and check the stats on a Blank TDK, Dvdinfo always seems to freeze up. I can't find anygood reason for it to happen, I've tryed ones with things burned on them and they seem to work fine. Has anyone ever had this happen to them or know of a way to fix it...??? thanx
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
That would depend on your burner and\or firmware. Not all burners nor firmware versions will support media info from blank disks.
I know that if you have a Ricoh with firmware version 1.64, you will be able to get media info from blank disks.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 20:42 -
what is wrong with these TDK?
By twister6 in forum MediaReplies: 21Last Post: 26th Feb 2009, 14:50 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 17:21 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 09:55 -
What should I do with these TDK's
By Waltj in forum MediaReplies: 6Last Post: 3rd Jun 2007, 00:27
