Hello there,
I just recently purchased the Adaptec Videoh DVD Media Center PCI edition and although i really like it. I don't really like WINDVR and Sonic MY DVD that much. They are okay but i was trying to find something that might work like both of them but be better? I want something that can act as WINDVR does in that it can work through your cable and record stuff when you want and all that and something that will do the file changing that My DVD does. Any Suggestions??
VirtualDub is a good piece of software, and free. It will allow you to do segmented captures, it's highly configurable, and most people online have some experience with it (good support).
Impossible to see the future is. The Dark Side clouds everything... -
Segmented captures allow users of Fat/Fat32 file systems (Windows 95/98/ME) to capture files larger than 4GB. They do this by breaking the capture file up into 'segments'. Essentially, each time the capture file approaches the size limits of the file system, the software creates a new segment. All of the segments can later be joined up for encoding as needed.
Need some software suggestions
By drtanz in forum EditingReplies: 0Last Post: 29th Nov 2011, 04:18 -
Software suggestions
By ereiamjh in forum Software PlayingReplies: 1Last Post: 8th Jul 2011, 13:56 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
Software Suggestions
By OtakuD in forum Authoring (DVD)Replies: 5Last Post: 1st Jan 2008, 02:29 -
By bmarthin in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2007, 04:56
