Not sure where this question belongs. I captured some .bmp stills using InterVideo's WinDVD capture feature. These .bmps are rather large(900k), and I would like to convert to smaller sized jpg, without losing the quality. Are there any good free/shareware programs that do this?
Thx
Actually, you can do this with Paint on Windows XP. Simply open up the bitmap with Paint, then save it as a jpeg. By the way, I think some quality loss is unavoidable when going from a bitmap to a jpeg.
http://www.webattack.com/php/download.php?id=101840
try this program"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
There are tons of freeware graphics editors avaialble for all flavors of windows. Try www.downloads.com
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
It doesnt matter what version of windows you have to convert the file. Just go to paint, open the file, and click save as and this time just type in the filename.jpg(or whatever extention you prefer).
I would suggest not using ms paint. It is great with bmp but when you try to save as a jpg you loose alot of quality (not what you want).
If you happen to use MS Office 2000 or later, try Photo Editor. It also allows you to control the level of compression so you can decide at what point quality is degraded too much.
It is not installed by default, but running the installer again will let you install it from the Office Tools section.
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 18:01 -
How to Save JPG / BMP output from *.swf files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2010, 03:32 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 15:54 -
DVD Flick importing jpg/bmp
By Soixante in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2009, 15:19 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 07:14
