I have a Leadtek TV 2000 XP Deluxe and I am a little dissapointed with the bugs and anoyin featres or lack there of in the software. I heard that DScaler is a good TVtuner program but I cannot get it to work. All I get is a blue screen.
My first thought is that maybe I need to know what is my tuner as although it detected the Leadtek TV2000XP Delux, the tuner said none and the NTSC tuners I tried did not work either.
Also assuming I can get it to work, is it possible to control Dscaler using the Leadtek remote?
After some more tincering and setting with signal detection I got a video signal, but I cannot get an audio signal. I tried the audio input options but got no audio with wither one.
Also the video works with any NTSC tuner so I was wondering which one would be the best for my card.
Thanks again -
Select the tv tuner which gives you both-audio and video-and also allows you to change channels. You have to go through the list of tuners and try them out one by one.
I tried all the tuners and then tried all the audio options for each tunner but I still could not get audio. Also, when I start the default Leadtek TV program the video image is completely scramled. If I change the country to something that uses a diferent system like PAL a d then back to USA cable the picture is restored but in some cases slightly worse then it used to be.
Anydy know why dscaler is hurting the default player? And any more ideas on how to get audio in dscaler?
TV2000 XP Expert No Sound
By cbr549 in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2010, 13:29 -
Dscaler & Greedy Highmotion
By DJUnReaL in forum EditingReplies: 0Last Post: 17th May 2010, 18:23 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
