help people, b4 i go insane!!!
i bought an LG4040b burner 2 weeks ago and have had no success backing up my movie collection, being a newbie i have read heaps on the subject because i thought i must be doing something wrong. what is happening is this....i burn a movie onto dvd-r and the burn seems to go well, it completes with no errors, but when i play it back on my comp or standalone player it starts getting choppy and eventually locks up, it always happens during the last half of the movie, i have tried different brands of media with still the same result, i have tried different software with the same result...but here's the odd thing, if i burn the movie onto a dvd-rw disc it plays back fine!!
my system is -
epox 8rda+
athlon 2000+xp
windows xp pro sp1
leadtek 4200ti vivo
1x 40g + 1x 80g hd
LG 4040B dvd burner
LG dvd rom
Pri ide - 40g hd master/80g hd slave
Sec ide - dvd burner master/dvd rom slave
pls..pls..pls can somebody figure this out for me![]()
Instead of saying help, help, how about telling us what your process for backing up your movies is (i.e. programs you are using to back-up with and what burning program you are using and what media (brand). Otherwise we will be trying to read your mind. You don't mention any of the above in your post. Want help, please post back with some information we can go on. Thanx.
This problem can be caused by the writer. i had the same problem its jst what the format that the writer is made to burn
Look up your burner in the WRITER section to the left. Read the comments other owners have left on what media works/doen't work for them.
Look up your Media in that section. Read comments there as well.
Put your writer name/model in the search box top-right on this page and look for threads found.
Do the same for your media.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
i have used the following for burning -
nero 6
pinnacle instant copy 7
dvd decrypter
dvd fab
dvd xcopy express
and the following dvd-r media -
princo 1-4x
verbatim datalifeplus
shintaro
my burning process has been
dvd5 to dvd5 with dvddecrypter
dvd5 to dvd5 with instant copy
dvd5 to dvd5 with xcopy express
dvd5 to dvd5 with nero 6
dvd9 to dvd5 with dvd decrypter + dvdfab + instantcopy
all with varying settings
hope this helps, i will search the forums some more, btw, firmware for the LG4040B is A300(the latest) -
My standalone DVD player (an old Panasonic A350 bought in 1998)
accepts both DVD-R and DVD+R formats, but only when they are burned
at low speed. 1x, 2x and 2.4x are OK, but 4x and 8x do not work.
If I burn a disk at 4x, the player freezes at half the movie. If I burn the disk
at 2x, the whole movie plays fine.
Perhaps your issue is similar. Perhaps you burn your DVD-R disks at 4x and
your DVD-RW disks at 2x ... at that's why only the DVD-RW disks work. -
thanks for the tips...i will certainly try them all...especially the burning speed vega...will post back when something changes, meanwhile any other suggestions gratefully recieved
DVD-lab burns DVD-Video, Ashampoo and ImgBurn fail... Why?
By nbarzgar in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 14:27 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 00:19 -
DVD burner only burns DVD-RW now and firmware problem.
By yocahu in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Mar 2010, 22:23 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 18:56 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39
