Evertime i burn data files to a DVD-R, it just won't let me add addition files to the disc the second time. It said the disc already contains data, adding new data to the disc may not work with some drive. The first time i burn it, i did leave the session open. This works with my CD-R's but not DVD-R. I'm using Raxio6.
any suggestions?
Results 1 to 12 of 12
I use DLA [drive letter access] system. Available with Record Now Max and/or Stomp along with other burning apps. It allows you to just use a DVD as if it were a big floppy. I have used it for years without any problems. If doing a straight data burn you need multi-session not open session.
PS: Roxio sucks and bumping your topic will not help your case.(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
If you add more files to the disc, the only drive that will read the disc is your original DVD-RW drive.
Are you guys using Nero express to burn? cause i can't anything that let's you burn on the original Nero.
Need to know of program to close session and dvd disk
By pedote in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2011, 20:31 -
Burning mutiple files
By Canary in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2010, 10:46 -
Mutiple (30+) AVI's to DVD; DVD plays only the first 15
By sudiptoghosh in forum Authoring (DVD)Replies: 2Last Post: 12th Apr 2010, 10:56 -
Only First Session readable on DVD Player-- Deep Burner
By deepakOne in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 03:13 -
Can only read the first session in a MultiSession recorded DVD?
By demf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Sep 2007, 12:16
