have an avi file that i checked for bad frames and removed(used guide fixing bad frames without losing any audio Guide 153907) plays well as an avi file but when I convert it to mpeg the audio goes out of sync when it reaches the bad frames i masked as per the guide. How do I fix the problem.
Also if you compare this quide to Guide 142555 Tenders V-dub mp3 freeze vbr audio and bad frames guide, this guide tells you to "click the yellow keyfram back once then mark this as start" where the guide I used (153907) does not. Both guides tell you "click the yellow keyframe forward one then mark this as end' Is this why I get my sync problem?
I could really use someone's help on this.
