I use DVD Decrypter 3.160 is basically an Image from the drive to a DVD. I use to burn everyday and not all of the sudden I get I/O Device Error. The Writer is is on a Secondary IDE itself. Now when I write it with Nero from 5.5 to 6.015 or DVD Dcrypter 3.16+ or so.. I get the I/O Device error.. stangely others are ok.
I have WinASPI 4.71 installed as well. I tried everything under the sun for more than 2 weeks now.. please help. Using Win2k with SP1, 2, 3,4 and post fixes.. what else can be the problem..I even changed to 8 different types of media.
Have you tried using SPTI as the interface rather then ASPI. I don't use ASPI anymore as it is not well supported anymore.
By the way, in Decrypter, go to tools->settings->i/o if you want to change the interface. -
Yes I do not use ASPI in the first place.. always SPTI or something .... I burn like 3-10 secs then it shows the I/O Error thing.. The DVD Writer is internal and DMA has been set and without it tried everthing still no go. I just need to distribute some of these tech docs on dvd asap
DVD Flick created image distortion
By Vianty in forum Authoring (DVD)Replies: 7Last Post: 28th May 2009, 03:17 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 23:25 -
Is it possible: Write ISO images to DLT?
By sdsumike619 in forum Authoring (DVD)Replies: 5Last Post: 8th Jun 2008, 22:09 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 21:29 -
Why won't image burn allow me to write AVI?
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 15th Nov 2007, 18:26
