    airgunonline site
    Ripped with Smartripper
    Used dvd2avi
    Encoded with TMPGEnc 2.0 using 23.97 fps, 2-pass avr.
    It was ok, but video was pretty bad. After manual IVTC, video was great, but audio was waaaay out of sync. Any sugestions. Is there something I missed. my pattern is 10110 which is what I entered.
  2. after ivtcing in tmpgenc, you have to set under the VIDEO tab, under format or something, to 3:2 pulldown on playback. or else your video will be 23.976fps but your audio will be "designed" for 29.976fps playback.
    setting this will solve sync problem.
    airgunonline site
    The thing that really has me stumped is that I am using 3:2 pulldown on playback, but that's exactly what it exhibits--there is more video information than audio--the last few minutes are silence since the audio has since ended.
    Finally I got really good video that will fit on 2 cd's and the audio is out of sync. Are you supposed to enter 5 digits for the IVTC pattern or less? Also when I use the check button in IVTC, it says sync stopped after this frame. Is this normal? and what does it mean?
    I've only been at TMPG for about a month and although I read the guides and have learned a lot more about it than when I started, there are quite a few times when I don't have a clue what's going on. Tried DVD2SVCD but at least with TEMPG I get usable results.
    Thnks for your reply
