I'm attempting to create a booklet for my cd. I've tried using NERO cover designer, but it does not print the front and back of the booklet next to each other (meaning, i can't just cut it and fold it in half, like I want to do). I've decided to try photoshop, but I'm not sure what size in pixels the booklet should be. Can anyone offer some advice? Not sure if what i'm asking makes sense, so I'll reexplain if its hard to understand.
I posted here because i wasn't sure if this fit anywhere else, so hopefully i'm asking in the right place.
I'll give the measuring a shot... I forgot that photoshop can convert inches/centimeters to pixels, duh
I'll give that surething software a shot if i can find it somewhere.
Thanks for the tips! -
Using surething, i'm trying to do what i described earlier, and I'm using the surething front booklet "product type." I edited the front, looks great. Now i want to edit the backside (there are two tabs at the top, Jewel Case Booklet - Front, and Jewel Case Booklet - Back), so i click Back, but I can't edit the backside. Any tips? I thought that maybe this option was not available for this "product type" so i tried a different brand such as Neato, and same thing.
EDIT: Actually, I can add clipart and text, but can't change the background, is there a way to edit the background for only the backside?
Issues with Dimensions on Export
By jherzog in forum MacReplies: 3Last Post: 19th Jul 2010, 16:29 -
bad video dimensions information
By bl88drg in forum Newbie / General discussionsReplies: 18Last Post: 28th Jan 2010, 23:02 -
What's the Dimensions for a Title Screen?
By blaqlion22 in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2009, 01:13 -
x264 - new pass with different dimensions, is it OK?
By kurbads in forum Video ConversionReplies: 16Last Post: 5th Sep 2009, 07:57 -
creating a Booklet??
By wan2no in forum Off topicReplies: 9Last Post: 25th Apr 2008, 20:27
is that brushed metal!!!!
