Er a fav brit trick is to take box to top of tallest building you can find...Yes we do have a few...and drop the aforesaid box over the edge. I find the quickest way to retrieve the box and its contents is too jump after it. Make sure you land head first as it dont hurt as much....Rather than take the long slow route via the stairs or lift (Never working anyway). The end result should be one opened box and contents that will never cause you any problems with installation or working.
There is another way which involves setting fire to the box but you need to find a way into the box first to ignite the burner.....A small drilled hole should surfice.
Btw. Never tried either version and i will take no responsibilty for any problems caused by using either of the methods mentioned.![]()
Results 31 to 60 of 114
Not bothered by small problems...
Spend a night alone with a mosquito -
I did it! I got it open! I read all these replies, bought -R axe (everyone says they're best, right)? And it worked.
OK, now what do I do? Do I take what's inside it out? How do I connect the box? Should I format it?
Please help! Urgent!
Oh..... and I want the highest possible quality from this box!
Thanks in advance.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Why is no one helping me!!?? >:v{ I've been waiting! What's wrong with this forum??!!!!
Originally Posted by Gees
BTW why would you open ddlooping's box?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
You are allll stupid!!! This board reeks!!! I'm going too where I can egt some real help!!! :cP
Originally Posted by tompika
I've got a box of blank Cds coming in, and no way to open them..... WHAT am I going to do.........................
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
blank Cds
or put them on floppies?There's no place like 127.0.0.1
Dumb people! All these idiot waisted posts about how to open a box when you could be doing something important like giveing me answers to my ACTAUL important problems!
I Just got a dual format Butner NEC 1300A, (dumb people with box problems)
I bought Oem (ha ha) but I got no instructions with it!
HELP, I got it installed just fine, but where do I light the pilot light on this burner??? Need help Quick! I got it installed In the wall between the bathroom and kitchen just fine with 3 penny nails, but can't find the pilot light.
Also I have searched and red all the guides, but still can't find where to get Dual Burner Feul!! I expect to need more - feul than + feul, so where can I get it? I will be using - as a suplementalcase heat in the bathroom, while + is mostly for backup heat in the kitchen to keep pipes from freezing when I am not home this winter. SO I really need more - feul. -
Overloaded - I think your best investment would be some RW fuel. I think you can use it again and agian and save loads of money! :c))) WOW!
Try it.
I am getting one I saw on a website. Better than yours! Bunson burner or sumthing. I think it's portable!There's no place like 127.0.0.1
The easiest way to open any box is to have it shipped. Just take the box to your local shipper or post office and arrange delivery of the box to your home address.
They must have special tools in the shipping depots because it is certain to arrive opened. -
They must have special tools in the shipping depots because it is certain to arrive openedThere's no place like 127.0.0.1
Hi all.
I am overwelmed by the number of replies and proposed solutions, so first, let me express my deepest gratitude:
*ddlooping expressing his deepest gratitude*
I haven't had time to try any of them yet, but I will as soon as I found a way to open the cupboard in which I stored the box.
I am affraid I will not be able to try anything involving explosives, power tools and the like though, as my doctor advised me not too.
The medications I'm taking tend to make me drowsy and that could be dangerous.
I could end up killing the cat, or worse, burning the carpet.
I think the best solution so far, and I don't mean the others are bad, is sending the box to myself via the post office.
It is bound to arrive opened.
My only concern is the box being sent to the wrong address.
If I managed to copy the registration key, I will probably try the yellow-box-cutter method first. -
Good luck with your box opening ddlooping.
Just in case things don't quite go to plan, do you prefer flowers or chocolates when visited in hospital -
Yes. Good luck. I will watch your cat for you 'til you recover. :c)
Just put him and his food & toys in a box.......... no wait........that might be a problem :c*There's no place like 127.0.0.1
Thanks for your words of encouragement, bugster, I appreciate it.
The friends who visit me regularly at the hospital would tell you I'm a chocolate man.
But I'm going there often enough for my treatment, so let's hope I don't end up there for trying to open a silly box. -
Hello Gees.
Thank you for your offer. I'll take you up on it if the need arises.
I do hope it won't though. -
One tip you get your box surely opened and delivered to your address:
send it from outside your country (let's say Mexico, if you live in America or Netherlands in Europe) to yourself.Put a green label outside with the text (gift/no value) and declare it as non toxic.
I'm sure , your opened box will be correctly delivered to your house (maybe not by mail, but other uniformed people).
As ou got a cat, a more quicker way is, to use the box as scratch tree.Wait some days, and the cardboard is stripped off. -
Thanks for the reply, Dragonsf.
This does seem like it would work, but I have been advised not to travel.
The last time I did, my luggage arrived at the right destination (it even flew in first class) but I ended up in the wrong airport (in the middle of suitcases and travel bags). -
One important side note...If you do open the box(I see you did) then you can no longer consider it new.
Please do not post "I have a new DVD burner and..." as we all know its not new anymore. Please refer it as fairly new, open box, or slightly used.
If you don't, we will know you are lying since Baldrick keeps a tally of all those who opened the box.
LOL -
I know those cheap flights:your luggage goes as first class airmail directly to your destination and you have some stopovers without any reasons (the only reason, I can imagine is, they have to pick up more passengers on the way).Just found it cheaper to go from cologne to frankfurt to paris to london to tokyo than directly cologne to tokyo.
(But I must admit, that is not too helpful with your problem).
If time is no issue, why not apply some water on the cardborad, until it's rotten? -
Originally Posted by Dragonsf
Thanks for the tip!There's no place like 127.0.0.1
This post has been reported to the box protection society" who are currently tracking down ALL box abusers. If you promise to abuse no more boxes you WILL be granted an amnesty.
RabidDog, my intent has never been to abuse the box, simply to open it.
Do you have any suggestion that wouldn't go against the "box protection society" rules? -
ddlooping, I'm going to get you!!!!
I went and got a boxcutter. 2 hours later the FBI Anti-Terrorist squad busted into my house. For some reason buying a boxcutter makes me a terrorist. I told them I'm jsut trying to open a box.
The bomb squad blew up my DVDR burner. After 4 hours they finally believed me when I said I wasn't a terrorist. Now they think I'm a Video Pirate because only Pirates would want to burn a DVD. This dam Pizza Van is in my packing space in front of my place, and it's been there 3 days. Everytime I go out to ask what it's doing it leaves. 10 minutes later a different pizza delivery van is there.
I'm so confused, your guide didn't say anything about Pizza Delivery trucks??? How much am I supposed to tip? I mean can I tip them the box cutter now that my box is blown up? I didn't order a pizza and they haven't delivered one, so maybe no tip? And if I tip the box cutter, then what am I supposed to open the pizza box with? Can I use the same guide or do I need to download a new boxcutter-codec?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
One of the more effective ways to get a box open is to wrap it in Christmas wrapping paper and place it under the Christmas tree, after telling your spouse and/or kids not to open it until Christmas.
Of course, this means leaving your Christmas tree up all year long, but then, doesn't everybody always say they wish every day were Christmas? This way it can be!
Don't forget to look at the guides for how to wrap your box. -
ebenton, this is by far the best method so far!!
Do I have to get married or have kids though, or can I use my neighbor's?
Any particular tree you could recommend?
I'm sorry to hear about your troubles, Gazorgan, but you cannot hold me responsible for what others suggested.
"...what am I supposed to open the pizza box with?"
You could try chewing through it, but it might spoil the taste of the pizza (if it had any to start with). -
Village Idiot,
Help!!!
I just realized, my printer will be here today according to the FEdex tracking, and I bet it will be in a BOX. AUGHHHH
All I have is this DVD Burner box guide. I need a printer box guide!!
SHould be here anytime between now and 5 hours! Unless they wait till tommorow.
And number 4 is still at the ISP, wish I were there! At 3k I'm not much of anywhere ,and getting there isn't very fast. -
I think you are safe eating the Pizza box without opening it.
the crusts are made out of the same stuff as the box anyway. -
ebenton:
That Christmaswas great but in this case wouldn't he need to wait until BOXING DAY or better yet invent a new holiday UNBOXING DAY
@ddlooping,
I'm sorry but I don't believe you have read the guides. You're just like any other noob who claims to have read the guides but can't find the answer.
However here is the answer:
1. Place box on table
2. Locate end that says, 'Open This End' or 'Open Here'
3. Remove selotape that is preventing box from opening
4. Inside you will find a package, it will contain you DVD burner
5. Remove excess wrapping (thats the wrapping you don't need)
6. Locate installation instructions
7. Read instructions
8. Ignore instructions and post for help here
Thats what I did and someone gave me help, although 100 other people posted sarcastic wise cracks.
Hope this helps,
Jukka
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 15:26 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / IPTVReplies: 7Last Post: 25th Feb 2013, 18:26 -
First time opening my DVD pixma i4500 - is there a dvd template for printin
By netrate in forum MediaReplies: 5Last Post: 14th Nov 2011, 08:06 -
Opening DVD Shrink 3.2 causes VGA to go Blank
By ppurdue in forum ComputerReplies: 2Last Post: 9th Oct 2007, 23:51 -
DVD Decrypter invokes instead of opening CD drive
By redss in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2007, 18:07
