I am finding that less than half the SVCD that I play on my dvd player using the header trick are working properly, which is really frustrating because I can usually get one cd of a movie to play fine but the rest of them will stutter.
I am using the same procedure on all the files:
-extract the mpeg file with ISOBUSTER
-run the header trick using TMPGEnc (I have tried using simple multiplex, multiplex, and both MPEG-1 VIDEO CD standard and non-standard)
-burn the converted mpeg with NERO
All the files that I have tried to convert play fine on the computer before I try to run the header trick.
One other thing, which may be absolutely nothing. After converting the mpeg, if I try and play it on my computer, if the picture comes up green and blocky, it will burn fine, if the picture comes up black, it will stutter after burning it. Could this be a problem with TMPGEnc settings?
Any suggestions would be appreciated as the ones that do work play excellent on my dvd player.
TIA
Results 1 to 1 of 1
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 08:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21
