well my problem is this: when i play the VCD that i just burned with nero, the result in my DVD player is just bad. frames skip ahead too fast, leaving the audio behind, playing, while the video is actually too far ahead. what i did was use DVD2AVI to make the d2v file out of the vob files i got using smart ripper. i tried the following settings with DVD2AVI:
1. just a regular 29 fps with regular 48KHz audio
2. forced film 23.976 fps with 48 khz audio
3. forced film 23.976 with 44.1 khz audio
4. just a regular 29 fps with 44.1 khz
then i tried encoding with TMPGENC using these template settings:
1. NTSC film, 23.976 fps
2. NTSC, with 29 fps
then i tried fiddling with the settings a little, i tried different audio settings, different aspect ratios, and i still get the same result.. the video skips ahead too fast for the audio.
help would be greatly appreciated
thanks
Originally Posted by Grind KingHello.
yes, as it turns out, it's the DVD player that was causing the sync problems. i guess i'm one of the few RCA owners that has major problems playing VCDs. I tried using my uncle's DVD player to play the VCD, and as it turns out, it played perfectly.
thanks for the help
cheers -
Don't feel bad cuz I have a rca dvd player too and it doesn't play some of the vcd's that I create. But it will play perfectly fine on my APEX 1500's, LENOXX 2003 & INITIAL 9510.
MKV Playback problems on Blu-Ray Player
By bob52 in forum Video ConversionReplies: 4Last Post: 23rd May 2012, 13:21 -
Playback problems using Oppo DV-951HD DVD player
By fadedhipster in forum Software PlayingReplies: 5Last Post: 27th Apr 2010, 12:05 -
Xvid playback problems with Maganavox 7006 dvd player
By biggyk in forum Video ConversionReplies: 4Last Post: 6th Feb 2009, 20:36 -
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 02:02 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41
