I'm trying to remove a logo using Logoaway in virtualdub. Ive set up the filter so the logo is removed in the preview window but am not sure what to select in virtualdub to save the logo removed avi. Can some one please help? :![]()
Hi,
Go to "Video" - "Compression", and decide the codec you want to use to save the file; Go to "File", "Save As AVI (or press F7)" and save you new modified AVI file to a location.
Bill -
Select under video "full processing mode" then select a type of compression, divx, xvid etc.
If you're converting it to an mpeg, then it's best to select no compression and frameserve directly it to your encoder. Look up Vdub frameserving for a guide."Art is making something out of nothing and selling it." - Frank Zappa -
hi thanks for the advice guys.
Now stuck as cannot get virtuldub to framserve with TMPGEnc. have read and read all advice in forums but nothing seems to work. TMPGEnc will not open file, says cannot open or not surppoted. Anyone got any ideas?
I'm useing TMPGEnc 2.520.54 and vdub 1.5.4
am really Stomped
You have to settup VDUB to frameserve. It won't do it with a default installation. Run the configuration settup and it should work correctly. In TMPG set your Enviromental settings to the VDUB reader and make it 2 higher than anything else.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Yes I had done the above. Installed the handler, etc. So tried another avi and it worked ok so problem with avi. then find this thread in forum by Ogami
Posted: Oct 06, 2003 04:41
Well did it and hey it now works!I had this same problem with certain files try to frameserve and tmpg says "unrecognised or unsupported" though they're not neccesarily xvid i'm having probs with, I've only just this morning found a way around it so here it is.
First open your .avi in virtual dub and set video to direct stream copy (the audio settings don't seem to make a difference here, mine was AC3 so i already stripped it to a wav so was set no audio!) then choose "save old format avi" only takes a couple of minutes. Then open this new file with virtual dub and frameserve as normal adding whatever filters you need, should now open in tmpg without a problem!! I've tried this on 2 files I was having major issues with and it solved both!
remove a logo using two videos
By mathmax in forum Newbie / General discussionsReplies: 32Last Post: 20th Sep 2011, 20:31 -
How to remove nasty animated logo?
By Bonie81 in forum EditingReplies: 4Last Post: 7th Jul 2011, 10:34 -
how do i remove logo
By gangers in forum EditingReplies: 1Last Post: 28th Apr 2010, 14:53 -
Remove Logo Without Re-encoding?
By midders in forum DVB / IPTVReplies: 2Last Post: 10th Nov 2008, 21:07 -
How to remove channel logo?
By dapix in forum EditingReplies: 10Last Post: 23rd Jun 2007, 10:06
