Hi All
I`m just about to start converting some old home movies to DVD and would like to know if i should use PCM audio or MPEG audio?
My worry is that if I author the dvd`s in a standard which is going to be phased out i will have trouble playing the DVD`d in the future.
Thanks For any help
Need more info to help you. Are you in the US or elsewhere? Does the file size make a big difference to you?
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I`m from the UK, the size of the DVD files doesn`t really matter my main concern is future compatibility
Stu -
Then you can use either as players in UK use both. PCM is much larger.
But... I saw a post from an expert here that said mpg audio is no longer a requirement, so for longevity sake, I'd stick with PCM or look into AC3.There's no place like 127.0.0.1
Thanks thats great, i just had a horrible thought of watching scilent films in the near future.
Yeah. :c) You wouldn't want that. Better safe than sorry. BTW it was an excellent first question.
How do you convert DTS to PCM
By ChrisDaMan in forum AudioReplies: 27Last Post: 29th Jan 2013, 03:32 -
Can't play PCM audio from MPEG made from MKV
By brianp6621 in forum AudioReplies: 10Last Post: 19th Oct 2009, 13:12 -
iv50 pcm?
By dinofava in forum Video ConversionReplies: 9Last Post: 11th Oct 2009, 10:33 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
