  1. I'm new trying to make a VCD Menu, but when it says created sucsessfully, i take it, put it in my DVD player, and it pops up saying C13:00 DISK DIRTY.... It runs fine on my computer?!? HELP ME!!
    DVD Player - Sony DAV-S500
    CD - Maxell CD-RW 650MB
    Program using to create menu, and burn - WinOnCd
    May 2003
    Pal Realm
    Could be simply a bad media choice.
    But there's too many variables to guess at.
    Start by looking up your player in the Player section to the left. Read other owners' comments about their experiences with various brands.
    Does it play VCDs at all?
    Next Look at Media section and check comments for that brand of disc.
    You need to narrow down the possibilities of what it could be. First thing to try is a different disc. I'd try a high quality RW first, if reports say your player does well with them.
    If you eliminate media, then next is step-by-step look at your whole process. It's back to the VCD guides and searches for similar problems/threads.
    Good luck.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
