Does anyone own one of these DVD writers? if so have you upgraded the firmware? did it make it better/worse? or have you experienced bed media types?...SasArchiver (as much feedback as poss would be gr8)
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
Sasarchiver,
The 401s I have originally came with F/Ware ES0E, and I have since set it to ES0G. In either case the writing ability has changed little. The results are fair in my case, though I have the ability to judge against a Ricoh MP5125 for comparison. Others have reported poor results on burning media.
4x writing to both +R and +RW is as promised. AFAIK there will be an improved version of firmware released very soon.
The drive will not allow for bit-setting to +R/RW media. This appears to be a non-event with this writer.
Stick with it and wait for the improvements in firmware. Lite-On will make sure it ends up a very capable +R/RW burner.
Regards
Studebarc. 8)
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 17:58 -
Liteon dvd recorder
By mangbok in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Jul 2010, 14:37 -
Liteon 5005 dvd drive
By kenmo in forum DVD & Blu-ray RecordersReplies: 8Last Post: 15th Jun 2010, 15:58 -
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 15:54 -
Help Liteon DVD recoder
By killingme in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Apr 2009, 18:46
