help is there any fix for ati all in wonder 128 so it can capture in colour from an ntsc signal?
it plays on the tv ok but when i capture in pal i have colour but i have a vertical hold problem 60hz roll or ntsc with a black and white picture but no screen roll is there a fix to capture in ntsc WITH colour..?
i use virtual dub for capture any help ???
<font size=-1>[ This Message was edited by: jord001 on 2001-07-09 15:52:02 ]</font>
Make sure your video source settings are correct - ie: if the video is coming in on an S-VHS cable or RCA (composite) cable. Also check the format (NTSC or PAL) settings.
My card will show B&W video if I choose Composite input (even though nothing is connected to the composite in), when in actuallity its the S-VHS input I'm using.
Hope that helps!
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 04:36 -
Trying To Capture NTSC VHS Video With UK Equipment
By pbar in forum Capturing and VCRReplies: 37Last Post: 21st Jul 2009, 10:59 -
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 02:17 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 17:58 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 08:25
