Hi,
I am a new forum user and wondered if anyone can help.
Just fitted a nec1300a (no software), I have an upto date version of Nero 5.5, but when it comes to writing to dvd data is saved to an image file on hard drive and thats it.
Do I need software for formatting the blank dvd discs first or could there be a problem with the drive.
Thanx
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 12 of 12
You don't need to format the blank media. Does the drive show up in Nero? I have a NEC ND-1300A and WinXP, Nero recognized it with no problems. You might have to select the NEC drive over your other drives. When I first installed my drive Nero defualted at first to my CD drive.
Does the drive show up in "My Computer"?
From Nero you should be writing to DVD-Video not DVD-data if you are Authoring a video. Then make sure you are writing to the disc and not making an ISO file. -
If it shows in Nero as a DVD drive then Im not sure what you could do?? Nero should work with all drives.
Does the DVD drive work? Can it play DVD's and/or CD's? Maybe it needs drivers or something?
Sounds as though your Nero is for the original CD writer only - I've got 3 versions all of which will only work with the drive they were bundled with. You'll need to get a new copy to use the DVD writer. You could try e-mailing Ahead to see if you can get a (cheaper) upgrade/new serial as you already have a copy of the prog. Alternatively, try one of the free burners from the tools section on here.
Life is what happens just when you've got everything planned. -
When I purchased my 105 it came with it's own version of Nero. I already had it installed from the one that came with my Liteon CDRW. The problem was that which ever version I installed last dictated what drive I could use. I contacted Nero and was givin the information that I MIGHT qualify for a special upgrade price. That was all they told me and when you look on there site, you can't find it. I asked a couple more times and recieved no reply. I finally got some garbage about sending in the serial number from my current version, but niether came with one. The end result was they wanted me to pay for the retail upgrade. I just couldn't do as I could LEGALLY use this software for both of my drives. In the end, I said good bye to Ahead and Nero forever! (At least sending money to them)
doesnt win/XP have native writing support built in? Dont think it will do dvd-video but will write to a drive.
The electronic components of the power part adopted a lot of Rubycons.
HD Audio Query
By anirban in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2011, 11:08 -
CD media query...
By mjl1297 in forum MediaReplies: 4Last Post: 17th Nov 2010, 23:35 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 05:36 -
LG2T160 Query
By coolboarderguy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jul 2008, 08:07 -
iTunes query
By melted_moonlight in forum AudioReplies: 0Last Post: 25th Jul 2007, 12:51
