Hello all,
I have captured video at MPEG-2 and MP3 audio (160 kbps). I would like to convert the huge MPEG-2 files to DivX, keeping the MP3 audio. My problem is that I am using FlaskMPEG and it cannot use the MP3 audio and multiplex it with the video for me.
1) It seems that my options are to get the audio in a separate file and multiplex it myslef (how do I do this? Can you recommend a good program for this, and is it a reliable process - is it usually always in sync?)
2) Or I use a different program which can deal with the MP3 and multiplex it for me in the original conversion from MPEG-2 to DivX.
I am quite new to all of this, and although I read up on it a bit, I have a lot to learn, and am not familiar with many of the programs out there.
3) Also, I am getting an Archos AV380 in a few weeks, but I read that it cannot handle variable bitrate DivXs, does FlaskMPEG create variable bitrate DivXs by default? How should I create videos that are playable on an Archos 300 series?
Thank you for your time,
PAUL.
Have you tried Virtual Dub mod? Maybe you can load your video into it, save it as a DivX file, call it a day.
Hello. -
Pay attention, you may be tested on this material. I said Virtual Dub mod, my young Jedi.
Hello. -
Yea what tommy knocker said. But what I want to know is, why did you capture the audio as MP3, and what capture program let you do that?
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
I only know of one program that will capture straight to MP3, but it doesn't capture video - it's audio only so I won't even mention it here...
dj matty b -
What are you starting out with? Is it a single MPEG-2 file with muxed audio (i.e., filename.mpg or filename.mpeg) or is it a seperate video file and a seperate audio file and if so what format is the video file (example filename.m2v)?Originally Posted by Ejoc
If you have a MPEG-2 file with muxed audio then you can use DVD2AVI which will seperate the audio to it's own file and then give you a D2V project file for the video.
You can then use the EXCELLENT program GORDIAN KNOT to convert the video to DivX or Xvid format.
There are some excellent guides on doom9 website on how to use GORDIAN KNOT.
It has been a while since I've fooled around with DivX but GORDIAN KNOT was always the best suite of software (it is actually several programs that work together) to create your final DivX file with audio.
- John "FulciLives" Coleman
P.S.
Are you sure your captured audio is MP3 and not MP2 ?"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Captured Video Clips
By Prepper in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 14:02 -
captured some video
By the_man_one in forum Capturing and VCRReplies: 10Last Post: 19th Aug 2011, 05:42 -
When converting video captured with a tuner card...
By CursedLemon in forum Capturing and VCRReplies: 5Last Post: 7th May 2011, 16:13 -
captured video with hauppauge card... video looks blurry
By granturissimus in forum Capturing and VCRReplies: 4Last Post: 2nd Feb 2011, 07:43 -
Help converting M2T(captured from HDDVR) to MKV
By xSasquatch in forum MacReplies: 1Last Post: 4th Jan 2010, 12:41
