I have Ulead Video Studio 7, and just suddenly it stopped capturing the audio. The video gets captured but the audio is not. Anybody know any thing?
What were you capturing, and what were your settings and how far did you get into capturing before you loas audio? How much disk space is left on your hard drive?
Hello. -
I just had my hi8 camera plugged in, it always captured both audio and video, but it just stopped capturing the audio. I tried the same thing in pinnacle 8 and it worked, but videostudio 6 & 7 wont capture will not capture the audio. I have plenty of hard drive space. the setting for video is the s-video setting and the audio is the same as i normally use. I just dont understand why it quit all of a sudden.
Sorry, one more question. What hardware didi you use to capture?
Hello. -
I have an ATI all-in-wonder video card that has a little box that plugsinto the card and has inputs for a/v plugs and s-video
Darn, I was hoping you and I had the same hardware. Now I am at a loss, sorry.
Hello. -
Click on the Volume icon in the tray->Options->Prop.->Recording and make sure line-in is selected and the volume is around mid level.Also check in Capture tab of VS and look for Options setting and make sure your line-in is selected.Lastly go to Setting->Control Panel->Sounds & Multimedia->Audio and make sure your soundcard is selected.
I've tried all of that. Like I say, It's only video studio thats not capturing the audio. Everything else is fine.
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 04:51 -
Need help on using Corel VideoStudio X2
By natural4862 in forum Video ConversionReplies: 8Last Post: 12th Jun 2011, 06:13 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 20:41 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 11:23
