Im trying to convert a divx file to vcd, and i get this error in vdub when i save wav, "Failuer streaming avi file: (cyclic redundancy check)" any suggestions on how to make this work? thnx.
LOTS of threads dealing with that problem. Try a search from right on this page and read how others resolved it.
Try "cyclic redundancy check" and/or "divx to vcd".
Good luck.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Scan for bad frames first?
"Art is making something out of nothing and selling it." - Frank Zappa -
i read another solution on the forums which called for scanning for bad frames using vdub mp3, this i did and when i deleted the key frames that were reported on the log and saved the new avi, i recieved the same cylcic redundancy error while saving. bah!
Vegas 10: saving audio tracks to seperate .wav file
By Toastie in forum EditingReplies: 8Last Post: 6th Mar 2011, 21:50 -
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 15:11 -
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 21:41 -
Saving dvd recorder hard disk videos says error
By xmanhattan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 14th May 2009, 12:16 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 01:35
