Any firewire 800 external dvd burners?
You already have this going in a poll. This is considered cross-posting. (you actually have 3 running that are basically the same.)
If you want to change it, and avoid a warning from the mods, go back into your original post here and change the subject (click EDIT) and ask a new question.
Now you've gone and bumped your own topic! :cD
You can always edit any post - add to it, etc.
Just some friendly advice. :c)
Good luck.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I have a DVD+R drive with 2MB buffer on an old P3 750 with 256ram and a slow UDMA-33 hard drive, and burning at 4x DVD+R has been working fine for me. I always quit all other applications and make sure it's not fragmented up.Originally Posted by portrower8
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
ExpressCard / 34 slot vs Firewire 800
By Sjogogo in forum MacReplies: 4Last Post: 6th Dec 2010, 01:54 -
FireWire 800 ... Worth It For Editing??
By Gromit137 in forum EditingReplies: 2Last Post: 19th Dec 2008, 18:08 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2007, 00:01 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 16:18
