i went and burned a backup of 2fast2furious on dvd+r . it works fine on home systems and the playstation but it dosent work on car dvd players, how do i get it to work on car dvd players?![]()
What program burned it, what settings were used, what media did you use?
Hello. -
i used dvd decrypter tmpge author, clone dvd.
also im reffering to aftermarket car dvd players -
what media did you use? Try another brand if that does not work then your player might not play DVD+R. Try DVD-R if your burner can burn DVD-R if that does not work your player does not play any burn your will need to replace that car dvd player if you want your back to play in your car.
Axis AX-0810 Car DVD
By Route74 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jun 2011, 00:43 -
hardstone DPM-62 Car DVD Hack
By aziznetstudio in forum DVD & Blu-ray WritersReplies: 6Last Post: 8th May 2009, 14:04 -
ASVM6271 Car DVD Player
By Pete W in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Dec 2007, 17:08 -
How to get audio track from DVD to CD, to play in car
By erinmck in forum MacReplies: 10Last Post: 18th Dec 2007, 22:51 -
DVD player in my car
By dan-mac in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 19:47
