doe's anyone know how to get rid of those annoyning counter's that appear in the top corner's of dvd screener's?
Results 1 to 13 of 13
I'm afraid you'll have to be a little clearer. What program are you referring to? Or are you asking about a set top player? Need more imformation.
In my opinion, he is bragging he has access to DVD screeners, DVDs that he gets to see before the general public. You can tell him about Logoaway, although I really do not think he cares, one oway or the other.
Hello. -
NO! im not bragging and i have no accsess to to dvd screener's!!!
i have just recently got hold of one like any of us would normally do and i dont like to see a time counter in the top corner of the screen its annoying!
it's a tottally ligitamat question.
so id appreciate a little help and a point in the right direction instead of some know it all claiming that it's all a bragg!
so id appreciate some REAL & USEFULL advice by some more helpfull member's. -
well -- "any of us would normally do" .. i guess you are in editing movies on an avid system or something , because those are smpte time code and frame counter (and often scene markers) , which are used on work prints for adding audio , ADR , effects and other such purposes ..
i add them all the time in the work i do .. to remove them .. you don't.
btw -- a "screener" would not have smpte time code burned in UNLESS (very very rarely) it was rushed for reviewing before final edit (this has happened) ..
all you could do is to crop it out or just use the original print like your supposed to do .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Put some black electrial tape over counter on the tv screen.
doesn't Vdub have a filter for this type of thing?
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I mentioned Logoaway, but I guess he is not interested.
Hello. -
Originally Posted by Roderz
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Yes it was a joke but I do know someone who does this honest!Put some black electrial tape over counter on the tv screen
and I told him about Logoaway (fell on deaf ears - he's still using tape) -
I still have black electrical tape on my VCR to cover up the blinking 12:00.
(2 years, and 14 re-reads of the manual and I still can't figure it out) Also use black tape for the Check Engine light in my car
Works great for those nuisance LED lights. I do this.Originally Posted by RoderzWant my help? Ask here! (not via PM!)
Adding Timestamp or counter
By hdbrandon in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2011, 18:06 -
Remove timer counter from avi
By patvison in forum Newbie / General discussionsReplies: 4Last Post: 19th Oct 2010, 18:10 -
Remove Counter
By Mark-Leon in forum MacReplies: 13Last Post: 29th Dec 2008, 12:12 -
Running counter in XVID movie?
By drwho in forum EditingReplies: 3Last Post: 12th Oct 2008, 04:21 -
Steam: Counter Strike, forwarded port but not working.
By StoneColdWhat in forum ComputerReplies: 2Last Post: 9th May 2007, 23:53
