Hi all - firstly, awesome site! V. Comprehensive and gave me a good intro for someone who knows nothing about dvd recording.
Now I have looked at a number of DVD recorders to buy to suit my purpose but so far I haven't come across anything that i think will do what i need it to, so i thought i would put it out to you to hopefully give me a hand.
i do a lot of casting for television so i record the casting sessions on dv tape then my plan was to record a shotlist of these from the dv camera to a dvd recorder (this might initially mean dvd-ram or a Hard drive). Then I need to chapter these so that once my dvd has been burnt i can easily skip beteen the cast and their individual takes. i recognise this is not a problem with dvd-rw (vr) or dvd-ram however because i will need to take this disc various places and i have no guarantee as to what their machines will and will not play then i think i need to burn dvd-r to be safe. my question is whether there is any machine which will allow me to chapter footage manually when burnt to a dvd-r format....oh and i'd prefer to steer clear of going the computer route.
so far i've looked at the Sony RDR-GX7, Panasonic DMR-E100 HS and the Panasonic DMR-HS2 but none look as though they can do this job...
can anyone help?
best regards - Ryan. [/b]
I can only help in recommending that you go back into your original post and change the title (subject) to something that describes the help you need. (Just click edit - go up to subject box and re-type.)can anyone help?
Many people skip over those titled "Help Me" etc. It could sit for ages.
I believe you'll get more replies if you try that.
Good luck. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Creating New Chapters from Existing DVD
By matthewjohn23 in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2011, 04:14 -
Creating an episode DVD with custom chapters
By Shinsui in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2010, 13:32 -
DVD-Lab - creating chapters
By Kimosabe in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2008, 09:41 -
Creating chapters from multiple video files in Sony DVD architect
By MTy in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 13:22 -
Creating Chapters On a DVD to Post on MySpace
By MsJoeCool in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2007, 11:13
