  1. Hi All,
    I had a search through the CC coments, and came across three Digital TV CCs that can be used in Australia:
    * Twinham VisionDTV Mini Ter
    * Nebula DigiTV PCI
    * WinTV Nova-t (PCI)
    Are there any other D-TV cards that I should be aware of that work in Aus?
    Cheers,
    Lucien.
  2. Member Sifaga's Avatar
    My m8 bought one of these and works really well on his PC
    AVerTV DVB-T
    we're in melbourne
    i am thinking of getting one but would have to upgrade my PC abit.
  3. Certainly will check them out.
    Any more recommendations....?
  4. Any more?
    LW.
  5. Bit off topic, but are these cards capable of acting as a digital receiver (instead of the use of a set-top box - converting analogue into digital signals) for free-to-air television?
    I use the Nebula in the UK for DTT grabs. Absolutely brilliant. You won't want to go back to analogue capturing ever again.
    energy80s,
    Fed up with my Hauppauge Nova-T I just bought one of these Nebulous things on your recommendation. Expect a flame if it ain't "Absolutely brilliant"
