    Jul 2002
    Scotland
    I would be grateful if some could advise why I get the following error when I boot up my pc. Should I fix the problem ? Or not ?
    Thanks.
    dlb.
    Yhe messeage reads :Pinnacle driver check detected problems with your driver settings. Would you like to fix these now.
    Yes / No
    The Hague (Netrherlands)
    This happened to me after installing Nero 6. I said No, and the next time I tried instantcopy it did not work, but it tried some kind of reinstall that failed (asking for instantcopy.msi I believe)
    However, I deleted the IC shortcut and made a new one myself (to the file multicopy.exe) This seemes to work.
    What happenes when you sat YES I do not know..
  3. Actually, you should select "yes." I believe it minimizes driver conflicts and I haven't experienced any ill effects. However, Instant Copy 8 and Nero 6 do not get along. If you have both of thees programs installed on your computer, you may experience errors (more like coasters) when burning with Nero. Sounds extreme, but I install Instant Copy only when I want to use it, then uninstall after I am finished because I use Nero much more frequently. I also set a restore point prior to installing Instant Copy.
  4. I think the issue is with Instant Copy's "virtual DVD" thingy. Uninstall that puppy and leave only the main program.
    Jul 2002
    Scotland
    Thanks for replies guys, been away for a day or two.
    I do not have Nero 6 installed, only 5.5.xx which seems to burn okay.
    I have not installed the Virtual drive on Instant Copy.
    At present I am not repairing the "error" which is being reported - I am not sure there is a error which needs to be fixed.
    There must be other IC users who have come across this problem and know what the error means.
    dlb.
