Is it possible to have more then 5 buttons on a menu??? When I do over 5 anything past that will not work and defaults back to the Players title screen (not the discs) - Please help
Col1701Guest
Hey,
I tried and it works fine. But when you create your menu put some space between the buttons else they might overlap each other and then there is only 1 button.
So maybe Chrissyboy can give us a grid to line out the buttons or a arrange button which makes spaces between the buttons. And it also would be nice to save the menu cause with this you have to make more then 1 try to do your dvd. And text align of the buttons would be nice to.Greatings,
Yf
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 18:45 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 08:13 -
Menu button for DVD Labpro 2
By warresg in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 10:37
