I use shrink, then imgtool classic to make an image. And i have fat32 so i use the option i imgtool, split images. In imgtool its says that splitted images is supported in DVD decryper.
But when i try in dvd decrypter i only get error...
/Abel
What error do you get, do you have the newest verison of DVD decrypter (see to mode | iso - write), and did you load the first image file?
I have version 3.1.6.0.
The imgtools make these files:
film.lst
film.iso_00
film.iso_01
film.iso_02
film.iso_03
film.iso_04
I have tryed to load them all. If i load film.iso_00 it writes the movie, but only a part of the movie. The other files gave me errors.
I thaught that u should load film.lst and than the program would write the other files automatic.
/Abel -
I think it would be easier to just format an older 10 GB HD to NTFS or put a NTFS partition on your HD so you don't have to fight with this.
Just a thought. -
why not buy a copy of record now max .... its an excellent burnig program an is well worth th us$39.00 (about £26 gbp) then rip with dvd decrypter in file mode or use dvd shrink and burn with RNM
dvd decrypter is for reading a pressed commercial dvd and moving the files onto your hard disc. IT is not a burning program or authoring program.. I think you may need to read more ...
Hi all.
RabidDog, I don't know the ins&outs of it, but as far as I know, DVD Decrypter can burn .ISO images. -
You've got to be stuck.
DVD Decrypter is not an authoring program you are right.
BUT...DVD Decrypter is all I burn with, I've never used anything else to burn
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 26th Jan 2008, 23:35 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 16:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 08:12
