Hey all, I have this movie that i downloaded which uses MP3 as the audio codec, i believe it is the Fraunhofer audio decoder. It works well it's just that whenever people speak in the movie, it is very soft and hard to make it out. Is there a way to "boost" the dialogue or is there another audio decoder that is better? thanks for info!
wow.. that seems complicated for a task this small, is there other MP3 decoders that i can use and perhaps configure the master gain volume?
Wow, five whole steps. Maybe it would be a little "over the top".
Hello. -
if you know.. which you don't, i'm the highest form of laziness.. i'm too lazy to crumple a paper towel.. ! so yah.. i guess i'll do it ur way
That's the problem. You are dealing with someone else's errors and often all the work involved to try to fix it is not worth it - especially if you're lazy! :c)movie that i downloaded
Got to go back to the ole "You get what you pay for" theory.
Good luck. Have a nap then have a go if it's worth it to you. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
LOL.. i've realized that turning the lil knob on my speaker to max is much easier than doing the 5 steps
, but thanks for the tips tho, i'll use them later on in life..
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 16:26 -
No dialogue, but other audio works fine
By MCPorche in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2012, 21:07 -
music + sound + dialogue = ?
By lovelove in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2011, 17:34 -
can't get external subtitle dialogue for AGK
By njitgrad in forum Video ConversionReplies: 0Last Post: 19th Jan 2011, 23:31 -
Spaces in Srt Dialogue
By Soixante in forum SubtitleReplies: 1Last Post: 10th Oct 2008, 17:49
