Hi, I am a newbie who just installed a Sony DRU 510A. The only media I have right now is Verbatim DVD-R 2X.
I am running XP Home, and I have the burner configured as the master on the secondary IDE channel, with a CDRW as the slave. The OS sees the drive, and I am able to read regular CD-Roms in it.
I've been trying to burn DVD Video using either Ulead MovieFactory or TMPGenc Author. I can't get anything to burn. For example, TMPGenc will start the burning process, and will stall at sector 304 (out of some huge number), then suddenly kick out the disk and give me a message indicated the job has been successfully completed. This takes all of 2 or 3 minutes.
So far, I have tried the two programs on 8 different disks (I bought a 10-pack). Can someone give me some advice?
Try a different brand/type of media, preferably a RW disc, so you don't waste more money, as a test and attempt to get a working disc out of it.
What you describe is what I've had happen with mine with incompatable or "bad" media.
Then go to : https://www.videohelp.com/dvdwriters.php?DVDnameid=102&Search=Search&list=0#comments
and bookmark for user comments about what media works/doesn't work with your burner. (Add your findings to help others also.)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I had a similar problem with my first DRU510A drive. It created coasters of -R media, I tried Verbatim 2x, CompUSA (FMI) 1x and Kypermedia 1x. It had no problems writing to different brands of +R media.
Apart from trying different media, I tried uninstalling and re-installing driver, multiple buring software, updating firmware with all sorts of combinations of the above.
After createing about a dozen coasters I went and had the drive exchanged at the place of purchase and the new one works like a charm. No coasters yet. -
That's really discouraging. I just did some more experimenting, and successfully burned to a Memorex DVD RW-, but failed (the same type of error) to a TDK DVD R-. How did you get an RMA? Did you deal directly with Sony?Originally Posted by mr_jbloggs
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony DRu 840 dvd RW Tray won't stay closed
By scustalow in forum ComputerReplies: 1Last Post: 30th Apr 2008, 12:39 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
