  1. I just successfully made a 2 SVCD to 1 DVDR transition with SVCD2DVD. Awesome...so naturally I moved on to my next SVCD to transfer. This is an XSVCD so that may be my whole problem.
    This is the error I get when I try importing the video asset into DVD Maestro...
    Temporal Reference in GOP #0 (Zero-based) are out of sequence (0xc10b000a)
    ...and then it won't import. I followed the DVD Maestro instructions on the website like I did for the one that worked but no luck on this one.
    Any ideas?
    ZenTsang Out!!
    "Long Live The Soil Monkeys!!" (tm)
  2. If i read this right you use svcd2dvd to make you ES stream files which you import in to maestro?
    I so you could try to do the proces by hand. tmpgenc to demux and besweet to reencode the audio and then import it in to maestro. If that failes then your source is the problem. If not then svcd2dvd might be the problem.
    Greatings,
    Yf
