  1. i have some d/l startrek ds9 episodes thery are dvd.avi files.
    some of the files are xvid and some are divx,i was wondering can i put,lets say 5 episodes onto 1 dvd as avi files or do i have to go through the llllllllllllllong process of converting all of them into mpg1 first?
    if i have to recode them all to mpg1 first which would you say is the best programme to use to shrink them so i can put say 5 episodes at a time on dvd?
    all your help would be gratefully appreciated to whoever responds please.
  2. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    dvd.avi
    not see that format before.
    Yes - as log as they fit on 4.3G dvd, they will work fine on your PC.
    BTW. I assume you own the originals of startrek ds9 episodes
  3. Look you muppet
    Do NOT give warez.
    Do NOT link to warez .
    Do NOT ask for warez.
    Do NOT provide information how to obtain warez.
    Do NOT advocate warez.
    Warez includes pirate/bootleg movies(movies that are not yet released on DVD or VHS).
    Avi files cannot be used on a dvdplayer
    The electronic components of the power part adopted a lot of Rubycons.
    Dec 2002
    What's being implied is this:
    You've downloaded DivX/XviD files from a Copyrighted DVD source. That's a no-no.
    If they were timeshifted from on-air via a capture card, well then we would be in the grey fuzzy place.
    DVD Players don't play DivX/XviD files. DVD players may play VCD (which go on CD's), SVCD (also on CD's), and DVD's. It is possible to put 5 hours of material on 1 DVD, but it won't look very good if your not working from the original DVD.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
