Hi I have a Philips DVDR70 that I have transferred VHS to DVD on it
Now I have a computer with DVD Writer and want to transfer some of the footage from the dvd to computer re-edit and make menus and transfer back to DVD
Can anyone point be towards a guide or the correct software to use
Pretty new to dvd authoring/editing and stuff but ok with computers and software
AF
So, you have a DVD that you can get files off of through DVDrom drive?
Then you can probably start at the Authoring section on the left.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Trying to edit various source clips, different resolutions in Sony vegas
By sevenofone in forum EditingReplies: 4Last Post: 30th Jan 2011, 17:29 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13 -
Max Source Resolution for Philips 5982
By GrayStrickland in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Feb 2008, 09:24 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48
