I'm trying to backup "24 - season one". It's a 6 disk set, each with multiple episodes. I found many methods on copying to dvd-r, but I cant seem to find an easy way of copying to svcd. Does anybody have a guide or a good method of copying each episode individually? (preferably two 1-hour episodes per disk?)
-Yar, matey!-
maybe this can help:
https://www.videohelp.com/forum/viewtopic.php?t=172677
two 1-hour episodes per disk? that's pushing the limits there a bit. its better to fit one episode per disc. you get better quality.His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Well, one episode per disk would mean using up 24 disks! Thats a bit extreme...but I guess it would be better quality.
^ Is there a way of batch converting the episodes so I can do it all over night? And for some reason when i use tmpgenc alone (instead of with dvd2svcd, which takes too long because its indivisual episodes), the video comes out shaky...it looks like an earthquake in the movie :P anyone know why?maybe this can help:
https://www.videohelp.com/forum/viewtopic.php?t=172677-Yar, matey!- -
I just use a bat file to do the whole thing for me, I havent done 24 so I dont know how its on the DVD, 1 PGC w/ all episodes, 1 PGC per episode, different PGC numbers from DVD to DVD... I encode lots of TV Series DVDs to CVD, but no two are exactly the same. Here's an example of my stargate sg1 bat file. Click my link and you'll find I have some other ones.
Code:REM Version 1.2 @REM Set Program Locations @SET DVD2AVI=C:\PROGRA~1\DVD\DVD2AV~1\dvd2avi @REM http://www.dvd2dvd.org/DVD2AVI%201.76%20Command-Line%201.05.zip @SET DVDDECRYPTER=c:\progra~1\DVD\DVDDec~2\DVDDec~1.exe @SET VCDXBUILD=c:\progra~1\dvd\vcdeasy\vcdimager\vcdxbuild.exe @SET NAUTOW=c:\progra~1\nautow\nautow.exe @REM http://www.stokebloke.com/software/nautow_0.0.4.exe REM @SET TMPGENC=C:\PROGRA~1\DVD\TMPGEN~1.152\tmpgenc.exe @SET TMPGENC=C:\PROGRA~1\DVD\TMPGENC2.5\tmpgenc.exe @set WORKINGDIR=c:\media REM Rip start /w %DVDDECRYPTER% /MODE IFO /SRC E: /START /CLOSE /VTS 1 /PGC 1 /DEST "%WORKINGDIR%\sg1\" start /w %DVDDECRYPTER% /MODE IFO /SRC E: /START /CLOSE /VTS 1 /PGC 2 /DEST "%WORKINGDIR%\sg2\" start /w %DVDDECRYPTER% /MODE IFO /SRC E: /START /CLOSE /VTS 1 /PGC 3 /DEST "%WORKINGDIR%\sg3\" start /w %DVDDECRYPTER% /MODE IFO /SRC E: /START /CLOSE /VTS 1 /PGC 4 /DEST "%WORKINGDIR%\sg4\" start /w %DVDDECRYPTER% /MODE IFO /SRC E: /START /CLOSE /VTS 1 /PGC 5 /DEST "%WORKINGDIR%\sg5\" REM Make D2V and WAV Files :convert if exist %WORKINGDIR%\sg1\vts_01_1.vob start /w %DVD2AVI% -IA=1 -Fo=0 -CS=2 -YR=1 -TN=1 -CF=4 -DRC=2 -DSD=1 -DD=3 -MA=2 -AIF=[%WORKINGDIR%\sg1\vts_01_1.vob] -OF=[%WORKINGDIR%\sg1\sg] -exit if exist %WORKINGDIR%\sg2\vts_01_1.vob start /w %DVD2AVI% -IA=1 -Fo=0 -CS=2 -YR=1 -TN=1 -CF=4 -DRC=2 -DSD=1 -DD=3 -MA=2 -AIF=[%WORKINGDIR%\sg2\vts_01_1.vob] -OF=[%WORKINGDIR%\sg2\sg] -exit if exist %WORKINGDIR%\sg3\vts_01_1.vob start /w %DVD2AVI% -IA=1 -Fo=0 -CS=2 -YR=1 -TN=1 -CF=4 -DRC=2 -DSD=1 -DD=3 -MA=2 -AIF=[%WORKINGDIR%\sg3\vts_01_1.vob] -OF=[%WORKINGDIR%\sg3\sg] -exit if exist %WORKINGDIR%\sg4\vts_01_1.vob start /w %DVD2AVI% -IA=1 -Fo=0 -CS=2 -YR=1 -TN=1 -CF=4 -DRC=2 -DSD=1 -DD=3 -MA=2 -AIF=[%WORKINGDIR%\sg4\vts_01_1.vob] -OF=[%WORKINGDIR%\sg4\sg] -exit if exist %WORKINGDIR%\sg5\vts_01_1.vob start /w %DVD2AVI% -IA=1 -Fo=0 -CS=2 -YR=1 -TN=1 -CF=4 -DRC=2 -DSD=1 -DD=3 -MA=2 -AIF=[%WORKINGDIR%\sg5\vts_01_1.vob] -OF=[%WORKINGDIR%\sg5\sg] -exit REM Make the AVISynth scripts :makeavs echo LoadPlugin("c:\media\avs\MPEG2dec3.dll") > sg.avs echo LoadPlugin("c:\media\avs\decomb.dll") >> sg.avs echo MPEG2source("sg.d2v") >> sg.avs echo Telecide() >> sg.avs echo LanczosResize(352,360) >> sg.avs echo addborders(0,60,0,60) >> sg.avs echo ConvertToRGB32() >> sg.avs copy sg.avs %WORKINGDIR%\sg1 copy sg.avs %WORKINGDIR%\sg2 copy sg.avs %WORKINGDIR%\sg3 copy sg.avs %WORKINGDIR%\sg4 copy sg.avs %WORKINGDIR%\sg5 del sg.avs REM Make the MPEGS :encode set TBEFILE=c:\media\tbe\stargates4.tbe if exist %WORKINGDIR%\sg5\vts_01_1.vob set TBEFILE=c:\media\tbe\stargates5.tbe start %TMPGENC% %TBEFILE% /batch REM Close TMPGEnc when done %NAUTOW% WI00:"TMPGEnc" WI01:"Result" BT00:"OK" WI02:"Project" BT00:"Cancel" WI00:"TMPGEnc" SY01: QUIT: REM Make the Bin/Cue files :build %VCDXBUILD% -p -b %WORKINGDIR%\sg1\sg.bin -c %WORKINGDIR%\sg1\sg.cue %WORKINGDIR%\sg1\sg.xml %VCDXBUILD% -p -b %WORKINGDIR%\sg2\sg.bin -c %WORKINGDIR%\sg2\sg.cue %WORKINGDIR%\sg2\sg.xml %VCDXBUILD% -p -b %WORKINGDIR%\sg3\sg.bin -c %WORKINGDIR%\sg3\sg.cue %WORKINGDIR%\sg3\sg.xml %VCDXBUILD% -p -b %WORKINGDIR%\sg4\sg.bin -c %WORKINGDIR%\sg4\sg.cue %WORKINGDIR%\sg4\sg.xml %VCDXBUILD% -p -b %WORKINGDIR%\sg5\sg.bin -c %WORKINGDIR%\sg5\sg.cue %WORKINGDIR%\sg5\sg.xml exit REM Shutdown C:\WINDOWS\RUNDLL.EXE user.exe,exitwindows
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Convert Multi-episode DVD to 1 avi file
By cfs6254 in forum Video ConversionReplies: 2Last Post: 16th Jan 2011, 02:26 -
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 22:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 16:39 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32
