  1. Hi,
    I just converted a 700mb avi media file to a mpg file using TMPGenc.
    The conversion took something like 9 hours, and the mpg file is now 3.3Gb in size! The avi file plays for 1 hour 50mins, but the mpg file plays for 5hours +.
    How many 80min CDR's will that take and who wants to spend over 5 hours watching the same film???
    Help please
    Bob Heselwood
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Filesize depends on bitrate and length of the clip. Are you making a VCD, SVCD or DVD mpeg? What settings did you use?
    Your CPU is the reason it took 9 hours.
    I suspect your file has bad frames, scan it with Virtualdub.
  3. Originally Posted by welz400
    Your avi file almost certainly has VBR audio, Tmpgenc does not like this and what you describe is a typical result. To check if this is the case, then open the avi file in virtualdub. If it gives a warning about the file containing VBR audio then we are on to a winner. In that case take a look at my second post in this thread https://www.videohelp.com/forum/viewtopic.php?t=181335&highlight=
  4. Yes that is/was the problem....CBR. So I am now going to do what you advised in the link to the other post.
    Funny thing is that I used TMPGenc to convert another avi file to mpg, which I burnt to a CDR, the went to play it on my DVD (plays anything) player, but the video stopped after a few minutes, and the audio continued! So I checked the original avi file, then went to re convert with TMPGenc, but guess what? It is now the same as the other media file I want bto convert. It wasn't before??
    say la vie!
    Thanks for your help
    Bob Heselwood
