Hello all,
This is what I have done so far:
(1) Extracted 3 DVDs with DVD Decrypter
(2) Then using the DVD Shrink, I have used the reauthor feature to extract certain scenes only. Then I have backed them up to 3 different folders(each folder containing different VOBs).
Here is where I am lost now. How do I burn these multiple folders to a DVD-R. I normally use COPY 2 DVD. I tried looking at the guides, but was unable to find anything.
Any help would be more than welcome.
Thanks in advance.
You don't burn the folders. You must join all videos to ONE folder. Use dvd shrink or dvd2one.
dvds to one dvdr guides:
https://www.videohelp.com/guides?formatconversionselect=DVDs+to+one+DVDR -
Thanks for the prompt response. Could you please clarify
"You don't burn the folders. You must join all videos to ONE folder. Use dvd shrink or dvd2one. "
When I was using DVD shrink to back up the multiple VOBs, I get a message that you already have the VOBs in one folder. Hence I had to create multiple folders. So now I have 3 folders with the VOB files (each backed up by DVD shrink). So how do I combine these three into one folder.
I looked through the guides, but I was unable to get the desired info.
ANy inputs would be welcome.
Thanks. -
http://www.dvdshrink.info/re-author-v3beta5-advanced.php
or
http://www.doom9.org/index.html?/mpg/dvd2one.htm (scroll down to join mode)
both guides linked from the link I gave....
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 17:22 -
What is the best way to combine multiple titles into one title?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 10:39 -
Possible to combine multiple ISOs to one DVD?
By SixOclock in forum Authoring (DVD)Replies: 2Last Post: 31st Aug 2009, 07:27 -
Help trying to combine multiple titles into one
By Muskogeee in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2009, 01:35 -
Combine multiple DVD clips in Adobe Premiere Pro
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 12:55
