  1. have been encoding fine for months using the guides on here, but all of a sudden TMPGEnc doesnt work properly.
    After pointing the proggy to my AVI and WAV files and setting bitrate to fit under 4000mb, instead of combining the two as normal into a MPEG file it tries to create a m2v+wav extension.
    What the hell is going on and how to I top it doing this
    PS the output video and audio and individual streams is ticked and greyed out
    VapoLianLi
    2.4b @ 3.6
    Abit IC7
    512 Corsair XMS3500
    ATi 9700 Pro
    Pioneer 106 DVD-RW
    LG DVD/CDRW Combi
    Samsumg 181 TFT
    2Mbit DSL :D
    Apr 2002
    The State of Frustration
    Did you check this:
    Hello.
    TMpgenc can't multiplex mpg and wav. You must join it when you author.
    If you want mpg and mpeg audio just select that
    in the wizard mode:
    if not the wizard just select System(video+audio) and under settings->audio->mpeg audio
  4. Originally Posted by Tommyknocker
    Did you check this:
    those options are all greyed out, and ES (Video+Audio) is shown as selected
    The output filename says .[m2v+wav]
    To give you some more info the AVI file is DivX 3 Low-Motion according to Gspot, and is a file I appended from 3 seperate AVI's using Virtualdub. Audio was exctracted and audio maximused and timewarped using Goldwav
    VapoLianLi
    2.4b @ 3.6
    Abit IC7
    512 Corsair XMS3500
    ATi 9700 Pro
    Pioneer 106 DVD-RW
    LG DVD/CDRW Combi
    Samsumg 181 TFT
    2Mbit DSL :D
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    tmpgenc CAN'T multiplex(join) mpv and wav. If you want one mpg video file you must use mpeg audio.
    BUT you can still use the mpv and wav in your dvd authoring tool. You add the video and then add the wav source and author to a dvd.
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    When using any of the DVD templates in WIZARD MODE you have your choice of selecting either CBR or VBR with either MP2 (Mpeg-1 Layer II) or LPCM auido. If you select MP2 (Mpeg-1 Layer II) then you will be able to select SYSTEM (VIDEO+AUDIO)
    Only when you select a DVD template with LPCM audio will you NOT be able to use the SYSTEM (VIDEO+AUDIO) option.
    - John "FulciLives" Coleman
  7. Originally Posted by Baldrick
    sorry - of course you are completely correct - selecting mpeg audio solves it Sorry big night last night and am feeling a bit fuzzy - thanks for the swift ans helpful replies guys!
    VapoLianLi
    2.4b @ 3.6
    Abit IC7
    512 Corsair XMS3500
    ATi 9700 Pro
    Pioneer 106 DVD-RW
    LG DVD/CDRW Combi
    Samsumg 181 TFT
    2Mbit DSL :D
